[GRASSLIST:5553] RE: Assigning colours to vectors
John Gillette
JGillette at rfmd.com
Fri Feb 14 15:15:41 EST 2003
Try d.vect.line and d.vect.area
You can assign a legend file to map category to color.
I am going to guess that the "standard colors" are the ones defined in
D_translate_color() and are lower case:
red
orange
yellow
green
blue
indigo
violet
white
black
gray
grey (same color, different spelling)
brown
magenta
aqua
John
> -----Original Message-----
> From: Brent Wood [mailto:b.wood at niwa.co.nz]
> Sent: Thursday, February 13, 2003 4:56 PM
> To: GRASSLIST at baylor.edu
> Subject: [GRASSLIST:5544] Assigning colours to vectors
> I've had a search through the docs & can't find the answer to this:
> How do I plot vector data with colours assigned by
> attribute/category ID?
> There are good facilities for assigning colours to raster,
> but not that I
> can find for vector data?
> Any help appreciated.
> Brent Wood
