[GRASSLIST:5568] Re: GRASS 5.0.1 compilation issues
Glynn Clements
glynn.clements at virgin.net
Sun Feb 16 12:38:54 EST 2003
Andreas Lange wrote:
> > I'm attempting to compile GRASS 5.0.1 on a SunBlade 1000. There are quite a few
> > "failed" messages in the config.log file. I assume that is normal. When I
> > "make" the package, the only errors written to "error.log" are
> > Compilation error in module: src/raster/r.tiff (ignored)
> > Compilation error in module: src/display/devices/PNGdriver (ignored)
> You need to install tiff and png packages (from www.sunfreeware.com) for
> the required libraries.
He didn't report an error regarding r.{in,out}.png, so I suspect that
he has the PNG libraries, and it's the lack of the GD library which is
causing PNGdriver to fail.
Glynn Clements <glynn.clements at virgin.net>
