[GRASSLIST:5597] Re: can't compile v.in.tig.rim in grass5
    Philipp Molzer
    phil at molzer.net
    Tue Feb 18 15:01:26 EST 2003
Thanks,
I got everything compiled and moved into the various appropriate
directories (scripts,etc/bin/cmd, bin, scripts ...) but am still having
problems:
I try:  (tried zone=T18 but got an error, so went with zone=18)
 v.in.tig.rim dbname=34013 in1file=TGR34013.RT1 in2file=TGR34013.RT2 zone=18
You must be in GRASS4 to run this program.
Seems like I'm being sent to
v.in.tg.rm.sh 34013 TGR34013.RT1 TGR34013.RT2 18
so I do:
export MAPSET=state1
export GISDBASE=/home/pmolzer/grassdata
export LOCATION_NAME=njstat1
export GRASS_GUI=text
this gets me past the GRASS4 test.
The script then dumps me into the rim shell, but unable to interact, so
I have to kill the v.db.rim process.
Neither  ESC-Enter or C-c work, nor do any of the rim commands.
v.db.rim seems to work fine in ineractive mode,
but I think that this part of v.in.tg.rm.sh:
# Build new data base
v.db.rim $DB << EOF
.in $ETC/db.layout
.ex
EOF
is causing me to get hung up.
Has the syntax changed for non-interactive mode and, if so, what is it?
thanks,
Phil
Glynn Clements wrote:
>Philipp Molzer wrote:
>>I'm trying to compile rim stuff (s.db.rim, v.db.rim v.in.tig.rim, etc)
>>for grass5 on Linux  2.4.18-19.8.0 i686 athlon i386 GNU/Linux.
>>I got s.db.rim and v.db.rim to compile by first compileing rim from
>>grass4.3 (couldn't find it in the grass-5.0.0 src)
>>Then I did:
>>mkdir /usr/src/grass-5.0.0/src.related/rim/LIB.i686-pc-linux-gnu
>>ln -s /usr/lib/librim.a \
>>/usr/src/grass-5.0.0/src.related/rim/LIB.i686-pc-linux-gnu/librim.a
>> and was then able to get s.db.rim and v.db.rim to compile
>>in /usr/src/grass-5.0.0/src.garden/grass.rim
>>BUT THEN...
>>I did /usr/src/grass-5.0.0/src.garden/grass.tig.rim/gmake5 and wound up
>>with:
>>make[2]: Entering directory
>>`/usr/src/grass-5.0.0/src.garden/grass.tig.rim/v.in.tig.rim/cmd'
>>gcc -I/usr/src/grass-5.0.0/src/include -g -O2     -c main.c -o
>>OBJ.i686-pc-linux-gnu/main.o
>>gcc -L/usr/src/grass-5.0.0/src/libes/LIB.i686-pc-linux-gnu  -o
>>/usr/src/grass-5.0.0/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.tig.rim
>>OBJ.i686-pc-linux-gnu/main.o -lgis
>>/usr/src/grass-5.0.0/src/libes/LIB.i686-pc-linux-gnu/libgis.a(flate.o):
>>In function `G_zlib_compress':
>>/usr/src/grass-5.0.0/src/libes/gis/flate.c:351: undefined reference to
>>`deflateInit_'
>>Is there some equivalent to v.in.tig.rim ? It seem like the easiest way
>>to import TIGER data.
>The module hasn't been kept up-to-date.
>You can fix the immediate problem above by adding $(XDRLIB) to the
>link command in src.garden/grass.tig.rim/v.in.tig.rim/cmd/Gmakefile,
>i.e.:
>	$(CC) $(LDFLAGS) -o $@ main.o $(GISLIB) $(XDRLIB)
>However, there may be other things which need to be updated.
