[GRASSLIST:5602] postgres and d.sites.pg
John Dougherty
jwd at softcom.net
Thu Feb 20 05:09:01 EST 2003
I need a little information regarding the use of d.sites.pg.
I find that a query that runs properly in postgres will behave differently
based on what interface I choose with d.sites.pg. If I use the tcltk
interface, I get an error regarding the "where" portion of the query. If for
instance I use 'where att ~* 'aa'" an error is thrown with a message that
'aa' is not a valid option, even though it works fine postgres. This same
error occurs if I use the command line using something like the following:
d.site.pg tab=gully map=boundary cats=att where="~*'aa'"
if run without the double quotations, but which states that attribute 'x'
cannot be found, when they are present.
If I run the command from the GRASS command line, answering the individual
prompts, the query runs properly and the results are plotted properly. Can
someone explain this?
John Dougherty
