[GRASSLIST:5606] Re: gdal install on cygwin
    Glynn Clements
    glynn.clements at virgin.net
    Thu Feb 20 11:21:05 EST 2003
Paul Dymecki wrote:
>    i was wondering if anyone has gotten gdal working with GRASS on
> cygwin.  I keep getting the compilation error _gdalmodule.so does not
> exist when running make install on gdal-1.1.8
I suspect that building a shared GDAL library doesn't work on Cygwin;
shared libraries are highly platform-specific.
Use "make -k ..." to ignore errors; it should at least install a
static library (libgdal.a).
When building GRASS, you will need to use "configure ... --with-gdal"
to force r.in.gdal to be linked directly against libgdal; the default
(without --with-gdal) is to load libgdal dynamically (like a plug-in),
which won't work on Cygwin.
Glynn Clements <glynn.clements at virgin.net>
