[GRASSLIST:5634] Re: gdal on cygwin errors
    Paul Dymecki
    millardymecki at sympatico.ca
    Fri Feb 21 14:22:01 EST 2003
Here's the gcc call from that group error messages.  I don't think i have
the right gcc version  because  -L isn't even an option as far as i  can
tell.
gcc -L/home/grass.src/grass5.0.1/src/libes/LIB.i686-pc-cygwin -o
/home/grass.src/grass5.0.1/dist.i686-pc-cygwin/etc/bin/cmd/r.in.gdal
OBJ.i686-pc-cygwin/main.o OBJ.i686-pc-cygwin/gbgetsymbol.o
OBJ.i686-pc-cygwin/gdalbridge.o OBJ.i686-pc-cygwin/make_loc.o \
/usr/local/lib/gdal.a /usr/local/lib/ogr.a /usr/local/lib/gdal.a
/usr/local/lib/cpl.a -lm -L/usr/local
----- Original Message -----
To: "Paul Dymecki" <millardymecki at sympatico.ca>
Cc: <GRASSLIST at baylor.edu>
Sent: Friday, February 21, 2003 1:46 PM
Subject: [GRASSLIST:5632] Re: gdal on cygwin errors
> Paul Dymecki wrote:
> > Hi,
> >     I was wondering if anyone can make sense of the following make
errors.
> > Platform: xp
> > gdal1.1.8
> > Grass5.0.1
> Paul,
> This presumably means that r.in.gdal was not being linked using a C++
> compiler, or linked against the c++ support libraries.   I am not too sure
> how to fix it.  Using "make CC=g++" might help.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
