[GRASSLIST:5266] Re: ARCViewImport too slow
Eric G. Miller egm2 at jps.net
Sat Jan 4 00:14:46 EST 2003
On Fri, Jan 03, 2003 at 07:25:57PM +0100, javier garcia wrote:
> Hello all and happy new year!
> I'm working with someone who uses ArcView and I need a dem that is stored in
> his ArcView. We are having serious problem importing it. In fact we can't do
> it.
> We have export it as a shape file from ArcView. And I'm using r.in.shape to
> import it. The translation into a ascii file is slow but a file is obtained
> (A 4.5 millions of lines one!), but r.in.poly is dispiriting slow.
> After 14 hours it is in the third pass of 26.
> I've stopped it because this is clearly not a good method to operate.
> Has anyone made this kind of ArcView export-GRASS import with distributed
> data as a dem with success?
You've got an elevation model? a raster?  You convert it to a shapefile?
How?  Seems r.in.ascii, r.in.arc, r.in.gdal, or m.in.e00 would all be
better ways to import raster data.
"...the plural of anecdote is [not?] data."  - attrib. to George Stigler
