[GRASSLIST:5272] mknod/mkfifo in cygwin
Jaro Hofierka
hofierka at geomodel.sk
Sun Jan 5 02:31:16 EST 2003
I have installed grass5.0.0 using cygwin on MS W2000 Professional. I
compiled the source code and everything went OK except for fifos in dev
directory. Apparently, cygwin does not support fifos because
when I enter mknod ot mkfifo command manually I get "Function not
implemented" error message.
So I am not able to start graphic monitor using d.mon command. NVIZ
works OK, but rather slowly.
I would appreciate any hint on how to fix this problem.
Jaro
