[GRASSLIST:5275] Re: mknod/mkfifo in cygwin
Jaro Hofierka
hofierka at geomodel.sk
Mon Jan 6 07:47:52 EST 2003
Eric,
you're right, the problem was in incomplete cygwin installation. Now it
works fine. Thanks.
Jaro
Eric G. Miller wrote:
> On Sun, Jan 05, 2003 at 08:31:16AM +0100, Jaro Hofierka wrote:
>>Hi,
>>I have installed grass5.0.0 using cygwin on MS W2000 Professional. I
>>compiled the source code and everything went OK except for fifos in dev
>>directory. Apparently, cygwin does not support fifos because
>>when I enter mknod ot mkfifo command manually I get "Function not
>>implemented" error message.
>>So I am not able to start graphic monitor using d.mon command. NVIZ
>>works OK, but rather slowly.
>>I would appreciate any hint on how to fix this problem.
> Sockets should be default for communications on all platforms. Unless
> you changed configuration options all the drawing commands should
> communicate with the renderers via sockets. I'm not up on cygwin
> builds, but that should be working. (replacing FIFO's was done
> specifically because windows doesn't support them.)
