[GRASSLIST:5279] No vector display
Vidya Kotamraju
vidyakr at darya.nio.org
Tue Jan 7 23:43:10 EST 2003
Hi all,
I have a vector ascii file for lines.
The header information and format of the file is as follows...
ORGANIZATION:NATINAL INSTITUTE OF OCEANOGRAPHY
DIGIT DATE: 2002
DIGIT NAME: grass
MAP NAME: globedem_goa_vout
MAP DATE: 2002
MAP SCALE: 1
OTHER INFO: /home/vidyakr/grass5/GrassData/test/PERMANENT/dig_cats
ZONE: 0
WEST EDGE: 73.5999984741211
EAST EDGE: 74.5916651925072
SOUTH EDGE: 15.0583334853873
NORTH EDGE: 15.8000001907349
MAP THRESH: 00.00
VERTI:
L 6
73.941 15.425
73.942 15.424
73.942 15.424
73.943 15.424
73.944 15.423
73.944 15.423
L 14
73.939 15.425
73.939 15.424
.............. and so on.
I ran v.in.ascii input=globe_vin output=globe_vout.
After which i run v.support map=globe_vout.
and build the topology information.
Grass then creates an empty globe_vout file in dig_att directory.
At the end of it all there is no vector display.
Where am i going wrong ?????
Another query is that i havent been able to get any info on the header format.
On what basis do we give the map threshold value (i believe this is the
minimum value between 2 points?correct me if i am wrong).
while creating the "test" database i selcetd lat-lon projection.Hence i hv
selected zone value as 0.
Also on what basis do i give map scale info ????
Regards,
Vidya.
Man is the only animal that blushes -- or needs to.
-- Mark Twain
Kotamraju Vidya
Physical Oceanography Division,
National Institute of Oceanography,
Dona Paula, Goa 403 004, India.
Ph.: +91-832-2456700 *4400 (O)
+91-832-2541756 (R)
e-mail: vidyakr at darya.nio.org
