[GRASSLIST:5302] Re: using GRASS in Emacs environment
SATO Masaei
masaei at tohoku.interq.or.jp
Sun Jan 12 08:21:38 EST 2003
Dear Clements,
Thank you very much for your answer.
> had heard of anything). There is an R interface to GRASS, which would
> presumably work with ESS.
Yes certainly, there is the GRASS/R interface which is able to working
with ESS. (I was suggested that by Mr. Furlanello in the statsgrass
mailing list.)
If the inherent commands of GRASS is available within the GRASS/R
interface, that is enough for me. But I don't know whether that is
possible or not.
I will use GRASS with shell-mode of emacs for the present.
Masaei Sato <masaei at tohoku.interq.or.jp>
