[GRASSLIST:5326] Re: GRASS5_mapserver and GRASS/Postgre
    Markus Neteler
    neteler at itc.it
    Fri Jan 17 11:44:27 EST 2003
On Wed, Jan 15, 2003 at 07:11:11PM +1100, shgervo at offratel.nc wrote:
> Hello
> 2 questions :
> 1-Grass5_mapserver
> I have been trying for 24 hours the 5 minutes grass5_mapserver
> installation ...with no result!
> compilations done :
> freetype-2.0.5, gd-2.0.9, proj-4.4.5,libgrass5-1.0.0,w3c-libwww-5.4.0,gdal-
> 1.1.8
> and mapserver-3.6.3
> http://localhost/start.html can find the mapserver.map
> when i select any of the options, the URL becomes :
> http://localhost/cgi-bin/mapserv?
> mode=browse&layer=soils&mode=browse&zoom=1&imgxy=250.5+200.5
> &imgext=590000.000000+4913392.000000+609000.000000+4928608.000000
> &map=%2Fusr%2Flocal%2Fhttpd%2Fhtdocs%2Fmap-script%2Fmapserver.map
> the only information I can find is the following error_log of Apache :
> File does not exist: /usr/local/httpd/htdocs/tmp/GRASSsb10426475507950.png
> (Directories and Aliases have been checked, as well as permissions; the
> refmap.png can be seen
> from the spearfich directory under htdocs)
> Is there any other error log specific for mapserver and where to find them ?
As far as I know there is only error_log which holds all errors.
Are you sure that Apache is allowed to read the .grassrc5 file? Is it in
the right place? See the README for libgrass5-1.0.0 for some details.
regards
 Markus Neteler
