[GRASSLIST:5351] Re: thanks but ps.map still doesn't work
Glynn Clements glynn.clements at virgin.net
Wed Jan 22 15:55:36 EST 2003
Carlos Henrique Grohmann de Carvalho wrote:
> Thanks for your answer, Glynn but ps.map still doesn't work. I selected a a4
> ps device, but all I get is a "no data" and a blank square below the map.
Another issue is that the colour table only includes categories which
have a label. If there are only a few categories, you can use
r.support to manually add labels. If there are too many categories to
do this, you could write a script to add dummy labels to the cats file
(<gisdbase>/<location>/<mapset>/cats/<mapname>).
Glynn Clements <glynn.clements at virgin.net>
