[GRASSLIST:586] Re: v.support messages - v.digit regrouping lines
javier garcia - CEBAS
rn001 at cebas.csic.es
Tue Jul 1 13:47:02 EDT 2003
Hi Matej;
No. I've got about 250 messages like that out of a map with about 6000
polygons.
I've opened the vector map with v.digit; and I can see that there is some
confused lines.
Some of the lines that were part of polygons have been combined, apparently
in a random mode, creating different "non-closed area edges". I've tried to
fix this wiht the Edit menu in v.digit, but I can't se how to do it.
I mean: all the lines are drawn, but I should specify that some of the lines
that appear as belonging to some area edges should be related no more, and
should be grouped in a different way, conforming closed area edges; then I
could create the missing categories. Is it possible to do this with v.digit?
Javier
El Mar 01 Jul 2003 17:34, escribió:
> On 2003-07-01, 15:01 GMT, javier garcia - CEBAS wrote:
> > PNT_TO_AREA failed: (685274.170389,4189408.706677) (Category 3876)
> If I understand well it just means, that one category (3876) label was
> mispositioned. Find that position and correct it with v.digit if it is
> necessary for you that to have that category.
> Matej
