[GRASSLIST:655] Re: Postgresql query
    Glynn Clements
    glynn.clements at virgin.net
    Tue Jul  8 10:52:42 EDT 2003
JDougherty wrote:
> I want to run a d.site.pg query that involes an 'OR' in the
> 'where' field.  Ideally it should be something like:
> 	select * from <table_name> where atr='A' or atr='B';
> The above works from within PostgreSQL.  d.site.pg however reports
> that 'OR' is not a valid option and that atr is not a valid
> parameter.  I am running GRASS 5.0.3 CVS and PostgreSQL 7.3.2.
If an option value contains spaces, you need to use quotes, e.g.
	d.site.pg ... where="atr='A' or atr='B'"
Glynn Clements <glynn.clements at virgin.net>
