[GRASSLIST:679] Re: raster categories and floating point attribute values
Glynn Clements glynn.clements at virgin.net
Wed Jul 9 23:17:16 EDT 2003
Steven Stoddard wrote:
> I am currently in the process of learning grass and trying to assemble
> a database to work off of for my research.  I am importing many files
> and trying to get them into a raster format that is amenable to
> analysis--floating point or integer maps.  I have maps though that were
> imported from .e00 that are in raster format, but are categorized
> sequentially (e.g. 1-120) and their labels are a floating point value.
> How do I get rid of the category number and instead have only the fp
> value so I can do manipulations with mapcalc etc?
You can access the category label in r.mapcalc using the "@" operator.
Consequently, you can create a new map which has the label in place of
the category using e.g.:
	r.mapcalc 'outmap = @inmap'
You cannot reclass an integer map to a floating-point map; reclass
tables are strictly an integer-to-integer translation.
Glynn Clements <glynn.clements at virgin.net>
