[GRASSLIST:687] Re: Postgresql
Thomas Hoffmann hoffmann at giub.uni-bonn.de
Thu Jul 10 09:34:13 EDT 2003
Try the command
g.select.pg localhost database=databasename
(insteed of localhost use the host name of the database-server on which
Postgresql is installed)
Good look
Thomas
Uttam Kumar schrieb:
> Hi,
>    I am using GRASS5.0.0 on Linux.When I select a database through the
> command g.select.pg, it gives a message "select Postgres:unknown host
> name: host". I think I have changed the host name in this command
> while using it before by mistake.I have heard that once the host name
> is changed then there is only one way to configure the host name back
> to it for the further working of Postgresql.This is done through some
> configuration in some Postgresql file.
> Can anybody guide me what is the name of the "file" where the
> postgresql host name can be changed and How ?
> Thanks.
> uttam.
> _________________________________________________________________
> HCL Beanstalk PCs. You could win one.
> http://server1.msn.co.in/sp03/hclbeanstalktour/index.asp Interested?
