[GRASSLIST:689] undefined symbol pj_get_def in r.gdal.in (grass51cvs)
Vincent Schut
schut at sarvision.com
Thu Jul 10 09:56:27 EDT 2003
I'm trying to get grass51 working. I followed the instructions for cvs
building, and everything builds fine. I can do the demo tour, also.
However, if I try to use r.in.gdal, I get the following error:
GRASS 5.1.0-cvs:/usr/local/src/grass51cvs/grass51 > r.in.gdal
r.in.gdal: relocation error:
/usr/local/src/grass51cvs/grass51/dist.i686-pc-linux-gnu/lib/libgrass_gproj.so:
undefined symbol: pj_get_def
I really really made sure that I have the latest GDAL and proj.4 on my system
(both from cvs), and no remains of older versions of these. I configured
grass with:
./configure \
--with-grass50=/usr/local/src/grass51cvs/grass \
--with-postgres-includes=/usr/local/pgsql/include \
--with-postgres-libs=/usr/local/pgsql/lib/ \
--with-freetype \
--with-readline \
--with-proj-includes=/usr/local/src/proj/src \
--with-proj-libs=/usr/local/src/proj/src/.libs \
--with-cxx
and tried several other things for the proj configure options, without any
difference. Running nm on grasslib_gproj.so shows several other undefined
symbols, apparently all from the proj lib. Is this normal?
My question: is r.in.gdal supposed to work in 5.1, and if so, how can I solve
this?
Thanks,
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
