[GRASSLIST:718] Negative elevations
Kurt Springs ferret_bard at mac.com
Mon Jul 14 19:16:24 EDT 2003
Hi folks,
As if you couldn't guess.   New question.
Some one opened one of the dxf files in ArcView.  It looked like it had
negative elevations.  When I ran v.surf.rst then v.color there was an
indication that some of my attributes were negative.  Is there a way to
correct this.  Maybe a way to add the the negative number making the
negatives zero?
Also is there a way to be sure the elevations are set to metres?
Kurt
