[GRASSLIST:760] Re: s.surf.krig
H Bowman hamish_nospam at yahoo.com
Sun Jul 20 20:42:08 EDT 2003
> is it (s.surf.krig) not included in a standard GRASS 5 distribution ?
> Where can I find it ?
It's in both
src/sites/s.surf.krig/
src.contrib/CERL/sites/s.surf.krig/
but those two are not the same.
The first looks newer.
From:  http://grass.ibiblio.org/grass5/source/README.html
Installing single modules from source:
The "configure" process creates two scripts (after "make install"
these scripts will be stored in /usr/local/bin/ if not having used
configure's option "--with-bindir")
   gmake5
   gmake5 -i
   gmakelinks5 -i
Use script "gmake5" to compile single modules locally, run
"gmakelinks5" afterwards to set internal links for the new module.
The "-i" flag will install them into target directory, so that no
further "make install" is required.
Enjoy ongoing GRASS development!
