[GRASSLIST:765] p.map.new & rast2gif (in GRASSLinks)
    Hayashi Shin-ichiro
    forest at bres.tsukuba.ac.jp
    Mon Jul 21 09:31:19 EDT 2003
Dear GRASS Users:
I'trying to install GRASSLinks.
GRASSLinks has "rast2gif" command to convert map file to gif file.
rast2gif-----------------------------------------------------
#! /bin/sh
trap "/bin/rm -f $TMP_PATH/grasslinks.$$.ppm"  0 1 2 3 5 9 15
GIF=$1
GRASTER=$2
GVECTOR=$3
GSITES=$4
VCOLOR=$5
SCOLOR=$6
GIF_SIZE=$7
SCRIPT=$TMP_PATH/pmap_script.$$
touch $SCRIPT
p.select ppm > /dev/null 2>&1
if [ $GRASTER != "none" ]
then
        echo "raster $GRASTER" >> $SCRIPT
fi
if [ $GVECTOR != "none" ]
then
        echo "vector $GVECTOR" >> $SCRIPT
        echo "     color $VCOLOR" >> $SCRIPT
        echo "     end" >> $SCRIPT
fi
if [ $GSITES != "none" ]
then
        echo "sites $GSITES" >> $SCRIPT
        echo "     color $SCOLOR" >> $SCRIPT
fi
echo "end" >> $SCRIPT
p.map.new input=$SCRIPT  > /dev/null 2>&1
case $GIF_SIZE in
    large)   MAX_RES=800 ;;
    medium) MAX_RES=400 ;;
    small) MAX_RES=200 ;;
esac
( $PBM_PATH/pnmscale -xysize $MAX_RES $MAX_RES < $MAPLP | $PBM_PATH/ppmquant 256
| $PBM_PATH/ppmtogif > $TMP_PATH/$GIF ) 2> /dev/null
The first half of this script works,(to echo "end" >> $SCRIPT )
Because this script makes "$SCRIPT" file.
But "p.map.new" command can't make ppm file.
Why can't "p.map.new" command make ppm file?
Please give me your suggestion.
And I have some questions.
1) "p.map.new" command demands parameter "GISBASE" and "GISRC".
    How does GRASSLinks read these parameter?
2) In this script, Which does p.map.new use ppm driver?
Glynn Clements wrote:
>I think that the PPM driver is disabled by default. Try copying the
>file etc/paint/driver.uninst/ppm to etc/paint/driver.sh/ppm.
GRASS has already have PPM driver in /*/grass/etc/paint/driver.sh/ppm .
On the other hand, GRASSLinks has PPM driver in /home/grass/grasslinks/paint/dreiver.sh/ppm .
Please give me your advise.
Thank you in advance.
Sincerely yours.
