[GRASSLIST:811] Re: postgres connection
mdeneen at japple.org
Fri Jul 25 10:32:56 EDT 2003
The reason I want to go straight to postgres is because when I try to
import using dbf, the dbf process grows up to 1000 megs before I kill it.
I don't know if I have enough memory to import the CompleteChain layer.
Is this something that will definately require a lot of memory?
-M
On Fri, 25 Jul 2003 mdeneen at japple.org wrote:
> How do I set up grass 5.1 so that v.in.ogr will import the data into a
> postgres table? I have found several tutorials, but they all deal with
> taking existing grass data and inserting it into a database.
> I'm sure it's simple, but I couldn't find the grass 5.1 documentation for
> it.
> -M
