[GRASSLIST:854] Re: 2: UNSOLVABLE problem in GRASS!!?
Glynn Clements glynn.clements at virgin.net
Tue Jul 29 03:16:38 EDT 2003
Ramin Safa wrote:
> GRASS:~ > r.mapcalc new="if(isnull(bound11r),slope11r%%,bound11r)"
> parse error
> Parse error
> I've checked any thing,but i dont know why eror?
You have to quote map names which contain any of the following
characters:
E.g.
	r.mapcalc new="if(isnull(bound11r),'slope11r%%',bound11r)"
Map names can be quoted using either single or double quotes; however,
when entering the expression on the command line, you have to take
shell syntax into account.
Also, you can't use a quoted map name on the LHS of the expression, so
r.mapcalc can't create maps which use any of the above characters,
although it can read them.
Glynn Clements <glynn.clements at virgin.net>
