[GRASSLIST:286] Re: d.vect.pg
    David Orme
    d.orme at imperial.ac.uk
    Wed Jun  4 05:24:44 EDT 2003
I tried that last night but only in the GUI version, where it produces
the same fault i.e.
> Sorry <Pacific> is not a valid option
> Sorry <Slope'"> is not a valid option <- note extra double quote...
That threw me off and I didn't think to check quoting the whole where
clause in the command line - which now works perfectly.
So something is going on with the tcltk implementation but I can now
use the command line.
Many thanks!
David
On Wednesday, June 4, 2003, at 10:15  am, Moritz Lennert wrote:
> David Orme said:
>> Hi,
>> Can someone help with the following behaviour in GRASS 5.0.0?
>> I've imported a shapefile (via v.in.shape) and passed the associated
>> dbf to PostGreSQL (via pg.in.dbf). All seems well with both the table
>> and the vector file by comparison to the original in ArcGIS.
>> If I use the tcltkgrass interface to perform a d.vect.pg select it
>> works, yet if I enter the same command at the command line it fails.
>> The outputs are below - the difference seems to be that the command
>> line version is stripping the quotes from the where clause.
>>> Executing
>>> SELECT Distinct _ID from globalebas_region  where  _name='Jamaica'
>>> and
>>> _ID is not null;
>>> 1 Rows
>>> GRASS 5.0.0 > d.vect.pg key=_ID tab=globalebas_region
>>> where=_name='Jamaica' map=eba color=red
>>> Executing
>>> SELECT Distinct _ID from globalebas_region  where  _name=Jamaica and
>>> _ID is not null;
>>> Error Connecting to Postgres:ERROR:  Attribute "jamaica" not found
>>> Mapset <dorme> in Location <global>
>>> GRASS 5.0.0 >
>> As a follow up, neither command line nor GUI seems to be able to
>> handle
>> spaces in text strings in the where clause. If I replace 'Jamiaca'
>> with
>> 'Peru-Chile Pacific slope' in the GUI then I get the following:
>>> Sorry <Slope"> is not a valid option
>> At the command line, I get the following:
>>> where=_name='Peru-Chile Pacific slope' map=eba color=red
>>> Executing
>>> SELECT Distinct _ID from globalebas_region  where  _name=Peru-Chile
>>> Pacific slope and _ID is not null;
>>> Error Connecting to Postgres:ERROR:  parser: parse error at or near
>>> "Pacific" at character 69
> Have you tried putting the entire where clause in double quotes:
> d.vect.pg key=_ID tab=globalebas_region where="_name='Peru-Chile
> Pacific
> slope'" map=eba color=red
> Moritz
