[GRASSLIST:319] Re: Printing site descriptions
Edmund Blackadder edmund at helmug.gr
Sun Jun 8 14:26:25 EDT 2003
If you want to make a good looking map, either export files in Arcview
format and work in Arcview, or export the eps and work in a drawing
programm like Adobe Illustrator.
Konstantinos Theofilis
On Sunday, June 8, 2003, at 06:29 PM, Glynn Clements wrote:
> Antonios Christofides wrote:
>>   [ When you print site descriptions with ps.map, you can't get rid of
>>   the border and background color, and you can't specify placement. ]
>> OK, so what's the workaround? You use the ps.map "text" command
>> instead
>> of printing site descriptions? How about when you have a map with many
>> names, such as a map with, say, 500 towns and villages? You create a
>> huge ps.map input file with 500 "text" commands? Is this a missing
>> feature of GRASS?
> Yes, it's a missing feature.
> GRASS is primarily an analysis package; its cartographic abilities are
> fairly basic.
> You may wish to look into GMT:
> 	http://gmt.soest.hawaii.edu/
> Glynn Clements <glynn.clements at virgin.net>
