[GRASSLIST:369] Re: NVIZ : getting a script to run
Glynn Clements
glynn.clements at virgin.net
Thu Jun 12 10:03:53 EDT 2003
H Bowman wrote:
> > > Use the ImageMagick tools:
> > The question is : does it work *inside* the nviz script ? Does "dump"
> > correspond to a temp file created during the script, before the
> > picture gets its proper name ? If not, well, back to the beginning.
> Those commands are just for the Bash prompt.
> By with the NVIZ script do you mean in:
> /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
> That's a Tcl/Tk script, I'd guess there would be a "system()" command in
> tcl, but I wouldn't know what it was.
"exec", e.g.
Although, if you're just looking to save space, and will be converting
back to PPM for processing, you may as well just gzip the PPM file:
exec gzip -9 file.ppm
PNG uses the gzip compression algorithm, so a .png and a .ppm.gz would
be roughly the same size.
> > Actually, I thought about a workaround: instead of relying on nviz to
> > loop on the maps, I rely on my bash parent. That way, I write only one
> > PPM that I can convert on the fly.
> Another ugly hack might be to have a cron job which runs every 20
> minutes: copy *.ppm to a temporary directory, convert everything in that
> directory to PNG, delete *.ppm in that dir, and move the PNG files back.
The key issue here is that you need to avoid processing a PPM that's
in the process of being written, so check the file's size or
last-modified time first.
> > Great ! Can I compile the latest version of NVIZ on a old version of
> > GRASS ? IS there a pb of backward compatibility ?
You would definitely need to use the CVS HEAD version of the OGSF
library (src/libes/ogsf), and I can't entirely rule out the
possibility that the latest NVIZ might depend upon some other changes
which have been made since 5.0.2.
Glynn Clements <glynn.clements at virgin.net>
