[GRASSLIST:400] Re: d.3d
Peter Slizik upsyptsl at savba.sk
Mon Jun 16 06:41:05 EDT 2003
Thank you for your answer, Paul,
> But you can also do scripting with SG3d or NVIZ; NVIZ has fairly good
> support for loading 3dview files now although you can't yet do it from the
> command-line.
But this is the root of all problems.  I need to write a bash script, which will
be run from a PHP script.  That's why I discarded NVIZ and switched to the d.3d.
-- Peter
