[GRASSLIST:452] g.setproj problem
Ian Macmillan ian_macmillan at umail.ucsb.edu
Fri Jun 20 19:48:55 EDT 2003
Hi all, I am trying to import a non georeferenced tif into a lat long location.
I received the standard error in this situation stating
WARNING: G_set_window(): Illegal latitude for South
As suggested in GRASSLIST 6203, I want to change my lat long location into an xy
location using g.setproj, import the tif and set the boundaries, then reset
back to lat long.  Here is the problem.  When I run g.setproj, I never get a
chance to set the projection.  A typical interactive session looks like this:
GRASS 5.0.0 > g.setproj
WARNING!  A projection file
'/Users/gans/grass/sonoralatlong/PERMANENT/PROJ_INFO'
   already exists for this location
This file contains all the parameters for the location's projection:
Latitude-Longitude
Overriding this information implies that the old projection parameters
    were incorrect.  If you change the parameters, all existing data will be
    interpreted differently by the projection software.
    GRASS will not re-project your data automatically
Would you still like to change some of the parameters (y/n) [n] y
The current ellipsoid is clark66
Would you want to change ellipsoid parameter (y/n) [n]
The ellipse information is not changed
Do you want to specify a map datum for this location?(y/n) [n]
Projection information has been recorded for this location
What is going on?  Is there a way to import a tif into a lat long besides this
method?  I am running GRASS 5.0.0 v2 (OpenOSX) on mac 10.2.6.
Thanks,
ian
