[GRASSLIST:514] Re: import HDF?
Markus Neteler neteler at itc.it
Wed Jun 25 03:47:15 EDT 2003
On Wed, Jun 25, 2003 at 01:41:29PM +0900, Alip.Yasin wrote:
> Dear GRASS users
> Firstly, Thanks Daniel, Alexpanton at btopenworld.com, Gonzalo for your kindly
> advice to looking for a Free Setallite Image).
> I am just downloaded a file named "V1KRNS10__19980601_NDVI__W-Asia" from the
> "Free Vegetation Products".
> After extract I got files
>     " 0001_LOG.TXT
>        0001_NDV.HDF
>        0001_QL.TIF
>        0001_RIG.TXT
>        0001_SM.HDF "
> For introduce into GRASS, I used "r.in.gdal" to 0001_QL.TIF, but it said
>     "PROJ_INFO & PROJ_UNITS file not found for location 'mylocation' ";
> For "r.in.gdal" to 0001_NDV.HDF file, it said:
>     "0001_NDV.HDF not recognised as a supported file format.
Could you send me the URL to the file? Then I'll try.
> For command "r.in.hdf " which I got a help typing  " man r.in.hdf ",
> it said :
>    "Command not found"
Right: the r.in.hdf is not completely updated. r.in.gdal is much better,
in case it doesn't work with above data the GDAL lib might be upgraded.
I could try to help here.
 Markus Neteler
