[GRASSLIST:536] Re: e00 import, creating reclass from dig-cats file (was: creating legend file for vector map)
Keith J. Forbes kforbes at gmx.net
Thu Jun 26 05:44:03 EDT 2003
On Thursday 26 June 2003 09:08, Moritz Lennert wrote:
> Keith J. Forbes said:
> > On Wednesday 25 June 2003 09:39, Moritz Lennert wrote:
> >> Hi Keith,
> >> (cc to the grass-users list, so that other can profit from our
> >> discussions
> >> > Dear Moritz:
> >> > Thanks for sticking with this.
> >> > Ok. something is weird here and I think it has to do with the original
> >> > import of the e00 file (source of the data). I copied the attached
> >> file
> >> > to ecol, and then ran v.support.
> >> > I checked with v.info, and the other r ones, as you suggested, and
> >> there
> >> > are 547 cats not 43. Now, each of these cats which from the file
> >> created
> >> > in dig_cats is basically a different ecotype. I would like each
> >> ecotype
> >> > to appear as a unique color and in the legend.
> >> GRASS texts can be a bit confusing in there use of the terms category
> >> and
> >> attribute: the attribute or category NUMBER is stored in the dig_att
> >> file,
> >> the LABELS (i.e. the descriptions) for the different attributes or
> >> categories are stored in the dig_cats file.
> >> So, when your file is imported, a dig_att file is created with
> >> category/attribute numbers, that don't necessarily have to be unique.
> >> Here's an example of the contents of such a file:
> >> A 163027.7718230 151474.5355770          1
> >> A 164207.9674190 172255.2677390          2
> >> A 189804.7270340 238558.1220960          3
> >> A 190347.9399790 238476.2118820          3
> >> It is this file that is used for the definition of the categories in the
> >> raster file. So if you have a dig_att file containing 547 different
> >> category numbers, then v.to.rast will give you 547 different categories
> >> in
> >> the resulting categories file.
> >> m.in.e00 creates different dig_cats files for each seperate attribute it
> >> finds in the e00 file. You correctly identified the one you're
> >> interested
> >> in and copied it to ecol, but this concerns the labels or descriptions,
> >> not the category numbers which are unique for each polygon.
> >> > I tried fooling GRASS by
> >> > creating a text file with columns as follows:
> >> > (normal header info)
> >> > 1:ecotype1
> >> > 1:ecotype1
> >> > 2:ecotype2
> >> > 2:ecotype2
> >> > 2:ecotype2
> >> > 3:ecotype3
> >> > 3:ecotype3
> >> > and so on for all 547
> >> > and then running v.support
> >> > GRASS did not like this at all.
> >> The numbers on the left should be unique and correspond to the numbers
> >> used in the dig_att file, so it is normal that this doesn't work.
> >> > So, I am going to try r.reclass on the raster file, and, after
> >> changing
> >> > all values to zero, change all the values for the same ecotype to the
> >> > same number (from 2-43). Then, I will run d.legend to see if it works.
> >> You need to use the dig_cats file to create reclass rules in order to
> >> make
> >> your category labels into category numbers. See
> >> http://op.gfz-potsdam.de/GRASS-List/Archive/msg08631.html for two
> >> different solutions to this. However, as far as I can see, only the
> >> second
> >> (the one in the cited section of the mail) will work if your labels in
> >> the
> >> dig_cats file are text (as is your cas). But I might be wrong.
> >> I hope this will solve your problems.
> >> Moritz
> > Moritz: Hi again.
> > Tried the second method as you suggested from
> > worked like a charm.
> > One question though. This process with the awk script and then using the
> > file
> > with a unique identifier for each label as follows as the basis for
> > v.reclass
> > and then v.support, would this be a much faster equivalent of a manual
> > interactive v.reclass or r.reclass, changing the value to the same unique
> > number for each label, and then running v.support?
> > 1=1 label1
> > 2=1 label1
> > 3=2 label2
> > 4=2 label2
> > 5=2 label2
> > to
> > 547 (in this case)
> > and so on for all the "categories" created by GRASS during m.in.e00
> > import of
> > e00 file in a particular label file (in dig_cats directory)
> I'm not sure I understand your question correctly. To me it seems obvious
> that typing one command line with the awk script would be faster than
> typing every single reclass rule myself...
> > Decided to get the GRASS book by Mitasova et al.!! My questions may be
> > less
> > easy in the future. ;)
> No, you'll start answering those of the others ;-)
> Moritz
Moritz:
The question was not regarding which method was faster! It was whether they
were equivalent in terms of results, and I deduce by your answer that they
are!
k|J|f
