[GRASSLIST:588] X Grass / cygwin / startxwin.bat
Dave Sampson
drsampso at mail.lakeheadu.ca
Mon Jun 30 22:59:27 EDT 2003
NOTE: Respond directly via-e-mail as listed above please
error
$ startxgrass.bat
xmodmap: unable to open file '/etc/X11/Xmodmap.127.0.0.1' for reading
xmodmap: 1 error encountered, aborting.
using:
startxgrass.bat
os:
win xp
cygwin
xwin
x11r6 lib
setup:
c:\os\cygwin\usr\local\grass5
status:
text based grass works
text base to tcltk& works
xwindows port does not work properly
what I've tried
I tried manualy moving grass/etc/x11 dir to c:\lang\etc\x11 but the system still hangs, but the xwin windows pop up for the GISDBASE/LOCATION.... screen
re-installed xfree86 files from cygwin setup... nothing happened
changed \'s to /'s cause I thought there might be a error (that messed things up more of course)
tried running startxwingrass.bat from the home dir c:\os\cygwin\home\d400s
it failed due to not finding xwin32...
I did a search and only found xwin.exe no xwin32
any ideas... any experieince
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030630/b0031640/attachment.html
