javier garcia - CEBAS wrote: > Is there any kind of problem with GRASS-GDAL if I want to install a new > version of gdal? Should I recompile grass again? It shouldn't be necessary, so long as the new GDAL library is called "libgdal.1.1.so". -- Glynn Clements <glynn.clements at virgin.net>
