[GRASSLIST:5765] Re: NVIZ segmentation violation
    Otto Dassau
    otto.dassau at gmx.de
    Mon Mar 10 15:37:31 EST 2003
Hi Martin,
>From the german list I remember you are using GRASS 5.0.0 or 5.0.1 on a
Suse 8.1 distribution, didn't you?
If I am right, your problem is, that NVIZ in GRASS 5.0.0 and in 5.0.1
does not support Tcl/Tk 8.4 which is part of Suse 8.1. If you need it,
you will have to compile a CVS snapshot of the GRASS 5.0 development
branch, because in CVS this problem is already solved.
You may test your tk version with
rpm -qa | grep tk
  Otto
