[GRASSLIST:5832] Problem with v.support
Kurt Springs
ferret_bard at mac.com
Fri Mar 21 20:13:44 EST 2003
Hi folks,
I am running GRASS 5.0.0 on OS X 10.2.4.
I used Adobe Illustrator to trace elevation contours. After some trial and
error, I exported to the contours to a tiff format and imported this into
grass as a raster file using r.in.gdal, then ran r.support. So far, so
good. I used r.surf.contour, then used r.contour to create a vector file.
When I run v.support, I run into trouble. The process goes on for about
three hours. During this time, I get a few warnings saying that the label
(in this last case 150 then 190) match another label (150 then 190). Then
the computer crashes in such a way that I have to restart. I had to run
Norton Utilities afterwards. Any idea what¹s happening, and more
importantly, how to fix it.
What I am doing is trying to create a 3D map of a region in my study area
using nviz. Can I do this from a raster map, using r.digit to set label the
contours¹ elevations?
Thanks for what ever help anyone can offer.
Kurt Springs
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20030322/5fc506e2/attachment.html
