[GRASSLIST:5835] Re: Compiling redhat8.0 update
Glynn Clements
glynn.clements at virgin.net
Sat Mar 22 09:03:17 EST 2003
sjors wrote:
> > Can you locate the corresponding error message in the config.log file
> configure:5288: checking for readline in -lreadline
> configure:5305: gcc -o conftest -g -O2 conftest.c -lreadline 1>&5
> /usr/lib/gcc-lib/i386-redhat-linux/3.2/../../../libreadline.so:
> undefined reference to `tgetnum'
OK; it's a known problem. At present, the only workaround is to
manually edit src/CMD/head/head, e.g.
READLINELIB = -lreadline -lncurses
and src/include/config.h, e.g.
/* define if readline exists */
#define HAVE_READLINE_READLINE_H 1
Unfortunately, it's far from clear as to which additional libraries we
should be checking for. Actually, it's fairly clear which libraries
are plausible (lib[n]curses, libtinfo and libtermcap), but the termcap
functions (e.g. tgetnum) are often provided by more than one of them,
and it isn't clear as to exactly which one we should choose.
Glynn Clements <glynn.clements at virgin.net>
