[GRASSLIST:5875] Re: problem of v.proj
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Mar 26 11:29:34 EST 2003
Hello
This is bug number 1052. The v.proj in 5.0.0pre4 is broken for locations
that don't have a datum specified (even though the datum isn't used in
re-projection). You can fix it by adding a line
datum: wgs84
to the second PROJ_INFO file.
Paul
On Wed, 26 Mar 2003, Xueming Wu wrote:
> Hello all,
> I want to transform some vector from Albers Equal Area project
> to Lambert project. But I got "segmentation fault" for running
> v.proj. Any suggestion? Thanks a lot.
> The following are some parameters of the two loactions:
> PROJ_INFO file:
> name:	 Lambert Azimuthal Equal Area
> proj:	 laea
> a:	 6370997.0000000000
> es:	 0.0
> f:	 0.0
> lat_0:	 45.0000000000
> lon_0:	 -100.0000000000
> PROJ_UNITS file:
> unit:	 meter
> units:	 meters
> meters:	 1.0
> And my Grass version is GRASS 5.0.0pre4.
> Have a nice day.
> Xueming
