[GRASSLIST:5879] problem of v.out.shape
Xueming Wu
xwu at cse.unl.edu
Wed Mar 26 16:19:17 EST 2003
Greetings,
I got "segmentation fault" when I used "v.out.proj"
to convert some vectors which was obtained by "r.poly"
from some raster". What I do were following:
r.poly
v.support
then
v.out.proj map= type=area
Segmentation Fault
But if I used type of line, the conversion was done.
i.e. v.out.proj map= type=line.
Any idea or suggestion? Thank you.
Xueming
