[GRASSLIST:5916] Shore Normal transect
John Chesnut
jchesnut at slonet.org
Sun Mar 30 10:57:42 EST 2003
I need to create shore normal transects from established sampling
points at Salton Sea, Ca.
How do I automate this in GRASS ?
The tangent point of a radius around the sample would work for this
relatively simple coastline.
In ArcView a "join" calculation records a tangent distance between
features. Is there a similar calculation available in GRASS. or do I
need to make a looping calculation that increments a radius until a
tangent solution is reached ?
A more complex coastline would require "smoothing". The normal
vector including the sample point would describe the shore normal
transect. This approach would require selection and creation of
seg,ments of the "smoothed" coastline. How would I automate the
selection process and store the locally smoothed segments.
