[GRASSLIST:6237] Re: gisdbase error
jose.anderson.batist jose.anderson.batist at itelefonica.com.br
Fri May 9 11:44:13 EDT 2003
Ok Markus, ok Glynn
Grass 5.0.2 has been just released, hasn't been?
I'm about to re-download the Grass (Xserver)!
In fact, 'usr\local\grass' might be damaged!
I'm gonna let you know my results
Thank you very much
José Anderson
> ---------- Mensagem original -----------
> De      : owner-GRASSLIST at baylor.edu
> Para    : Markus Neteler <neteler at itc.it>
> Cc      : grasslist at baylor.edu
> Data    : Fri, 9 May 2003 12:15:44 +0100
> Assunto : [GRASSLIST:6234] Re: gisdbase error
> Markus Neteler wrote:
> >  - graphical startup doesn't work  -> bug in Init.sh?
> >  - cmd line startup with path to GISDBASE doesn't work  -
> bug in Init.sh?
> Odd. At first I thought that it might be due to the use of
> bash-specific features (Cygwin's /bin/sh is ash) but, apart from an
> unrelated bug, it works with ash on Linux.
> The unrelated bug is:
> 	trap "echo 'User break!' ; exit" 2 3 9 15
> Signal 9 is SIGKILL, which can't be caught. bash seems to ignore thi
s,
> but it causes total failure under ash (attempting to run external
> programs fails).
> Can you provide more details regarding the failures? You can get
> debugging information by using "sh -x ...", i.e.
> 	GISBASE=/usr/local/grass5
> 	export GISBASE
> 	sh -
x /usr/local/grass5/etc/Init.sh /path/to/gisdbase/location/mapset
> Glynn Clements <glynn.clements at virgin.net>
