[GRASSLIST:27] Re: Raster cutting
    H Bowman
    hamish_nospam at yahoo.com
    Thu May 15 04:34:04 EDT 2003
> Is it possible using GRASS to cut out demanded shape of raster difined
> by polygon geometry? I am looking for tool like v.cutter but for
> raster layer.
If you have a *labeled* vector area already, just use v.to.rast then
r.mapcalc. Easy.
v.line2area, v.digit, and v.llabel might help you along.
If you just have coordinates, try r.in.poly with r.mask or r.mapcalc.
I use this all the time, works great. v.in.ascii can be useful too.
Read the r.in.poly, v.in.ascii, and r.mapcalc man pages anyway.
g'luck,
Hamish
