[GRASSLIST:62] Re: d.rgb question
Russell Nelson nelson at crynwr.com
Fri May 16 18:15:42 EDT 2003
Glynn Clements writes:
 > Using color=gray will map the lowest existing category to black and
 > the highest existing category to white; if the map doesn't use the
 > entire 0-255 range, you will get the wrong result.
Why is this left up to users to set correctly?  Why doesn't importing
an image do this automatically?
--My blog is at angry-economist.russnelson.com  | "I have officially heard
Crynwr sells support for free software  | PGPok | every excuse for being
521 Pleasant Valley Rd. | +1 315 268 1925 voice | assigned a single room at
Potsdam, NY 13676-3213  | +1 315 268 9201 FAX   | FGC."  --Liz Perch
