[GRASSLIST:191] Re: can't start mon under WinGeneric but can under X11
Jeff D. Hamann jeff_hamann at hamanndonald.com
Mon May 26 11:21:03 EDT 2003
tried that and still get the same results....
GRASS:~ > d.mon start=x0
ERROR: Graph_Set: can't open Display
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
GRASS:~ >
./configure --without-gd --without-odbc --without-fftw -enable-w11
wouldn't configure without the opengl so I configured with:
./configure --without-gd --without-odbc --without-fftw -enable-w11 --without
-opengl
it configured and installed but I still get the same problem...
Thanks,
Jeff.
----- Original Message -----
From: "Glynn Clements" <glynn.clements at virgin.net>
To: "Jeff D. Hamann" <jeff_hamann at hamanndonald.com>
Cc: <grasslist at baylor.edu>
Sent: Sunday, May 25, 2003 3:56 PM
Subject: Re: [GRASSLIST:179] can't start mon under WinGeneric but can under
X11
> Jeff D. Hamann wrote:
> > I've just downloaded and compiled GRASS5.0.2 (time to get to work
again..)
> > (WinXP) with the following options:
> [snip]
> > I *do* only want to
> > run the generic version though (less junk on the WinXP machine to deal
> > with).
> You need --enable-w11 to get the "generic" XDRIVER.
> Glynn Clements <glynn.clements at virgin.net>
