> >Also, can Grass create an index shape file for the tiles. > > Check out gdaltindex at http://www.remotesensing.org/gdal/index.html If you go with a script which changes the region and then runs r.out.tiff on the subsets, try using v.mkgrid as a starting point for the vector grid map. Hamish
