[GRASSLIST:254] Re: Grass interface to other languages
Peter Slizik
upsyptsl at savba.sk
Fri May 30 02:20:06 EDT 2003
In order to run GRASS commands from a script, the GRASS shell must be
running.
If it is impossible, eg. you want to run GRASS commands from a PHP script,
I'll suggest you to download the script 'batch-grass.sh' (Google will
find it for you).
Maybe the script will need some suble changes to accomodate it to your
needs (eg. change the way it treats its parameters), but for me, it
works fine.
Peter
