[GRASSLIST:269] Re: raster to vector conversion
    Matej Cepl
    cepl at surfbest.net
    Fri May 30 15:44:30 EDT 2003
On Fri, May 30, 2003 at 11:38:22AM -0500, Kirk R. Wythers wrote:
>> For transformation of plain bitmap to vector (without
>> georeferencing etc.)
>What if the image is georeferenced?
Then you have to make coordinate transformation of xy data. Make
brief abstract of [Neteler, Mitasova, 2002, p. 128] the procedure
should be probably as follows:
1) Stay in the location with the projection desired (i.e., in
   your case probably just stay in the original location)
2) Import DXF file (autotrace can produce .dxf files) as xy
   coordinated
      v.in.dxf -a dxf=vmap.dxf prefix=vmap
   It will generate a series of ASCII vector maps in
   $LOCATION/dig_ascii
   ls dig_ascii/vmap*
3) Import one ASCII vector map as binary
   v.in.ascii in=vmap.lines out=vmap_xy
4) Find four well visible points in the map, which may be used as
   control points. Switch to the imported map region (xy):
   g.region -p vector=vmap_xy
   d.erase
   d.vect vmap_xy
5) Using d.what find xy coordinates of the control points:
   d.what.vect map=vmap_xy
   write them to some file (e.g., ./control_points), just one
   line for easting and northing.
6) Switch to region of the original raster map (named for example
   vmap.r):
   g.region rast=vmap.r
   d.erase
   d.rast vmap.r
7) Using d.what.rest get georeferenced coordinates of the control
   points and write them to the ./control_points file to the
   other columns:
   d.what.rast map=vmap.r
   The resulting ./control_points file should look like this:
   838.8    244.2 1661701.3   5108172.4
   796.2    192.6 1661643.2   5108204.3
   796.2    91.6  1661543.7   5108181.8
   1110.6   379.0 1661864.4   51O8076.6
8) Make the transofrmation with v.transform (see its manpage for
   further info) and build its topology:
   v.transform input=vmap.lines output=vmap_trans \
      pointsfile=./control_points
   v.in.ascii input=vmap_trans output=vmap_trans
   v.support vmap_trans
   v.transform prints out RMS (root mean square) error for each
   ground control point, if these are too big ([Neteler,
   Mitasova, 2002, p. 130] gives 1.2 to 2.4 meters as an
   acceptable error for map 1:24,000), you have to find another
   control points and redo the transformation with new
   ./control_points file.
9) To verify transformation display two maps in the new maps'
   region:
   g.region vect=vmap_trans
   d.erase
   d.rast vmap.r
   d.vect vmap_trans col=red
   The result should match.
BTW, PLEASE reply to the list when asking further information not
to my personal address. It is selfish (because no one can find an
answer in the list's archives) and stupid (because noone can
control my answer) to do otherwise.
   Have a nice day,
      Matej
Matej Cepl, http://www.ceplovi.cz/matej
GPG Finger: 89EF 4BC6 288A BF43 1BAB  25C3 E09F EF25 D964 84AC
138 Highland Ave. #10, Somerville, Ma 02143, (617) 623-1488
Microwave oven?  Whaddya mean, it's a microwave oven?  I've been
watching Channel 4 on the thing for two weeks.
