[GRASSLIST:1637] Re: Installing grass57_exp_2003_10_25 on MacX
Markus Neteler neteler at itc.it
Sat Nov 1 05:44:34 EST 2003
On Fri, Oct 31, 2003 at 01:20:45AM -0800, Giacomo wrote:
> I've tried to install grass 5.7 on MacX:
An alternative is to download precompiled binaries:
http://mpa.itc.it/markus/grass57/macosx/index.html
If you installed GDAL from FINK, it is missing OGR.
That's why it won't compile. Try the GDAL-CVS or fetch
GDAL/OGR for MacOSX from above site.
Cheers
 Markus
Markus Neteler     <neteler at itc.it>       http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
