[GRASSLIST:1650] problem importing GMT grd files
Zbigniew Perski perski at us.edu.pl
Mon Nov 3 03:59:45 EST 2003
Hi all,
I can not import grd files type 1 (converted with gmtreformat to format
1 GMT) to Grass (5.0.2, running on i686 and i686 compiled from source on
those machines with Linux - kernel 2.4.22).
I am trying the r.in.bin -fh command and 4-byte
The GRD file:
grdinfo coherence.bin=1
coherence.bin: Title:
coherence.bin: Command: xyz2grd coh.xyz -Gcoherence.grd -I1c
-R7:42:13/8:41:26/49:35:29/50:12:17 -V
coherence.bin: Remark:
coherence.bin: Normal node registration used
coherence.bin: grdfile format # 1
coherence.bin: x_min: 7.70361 x_max: 8.69056 x_inc: 0.000277778 units:
user_x_unit nx: 3554
coherence.bin: y_min: 49.5914 y_max: 50.2047 y_inc: 0.000277778 units:
user_y_unit ny: 2209
coherence.bin: z_min: 0.0565573 z_max: 0.991879 units: user_z_unit
coherence.bin: scale_factor: 1 add_offset: 0
And Grass r.info:
  | Layer:    cohrenc                        Date: Mon Nov  3 09:48:08
2003    |
  | Mapset:   PERMANENT                      Login of Creator: knoppix
  | DataBase: /home/knoppix/grass_dbase
  | Title:     ( cohrenc )
  |   Type of Map:  raster              Number of Categories: 255
  |   Data Type:    FCELL
  |   Rows:         2209
  |   Columns:      3554
  |   Total Cells:  7850786
  |        Projection: Latitude-Longitude (zone 0)
  |            N:  50:12:17N    S:  49:35:29N   Res: 0:00:00.999547
  |            E:   8:41:26E    W:   7:42:13E   Res: 0:00:00.999719
  |   Range of data:    min =  nan max = nan
  |   Data Source:
  |   Data Description:
  |    generated by r.in.bin
So, why min max are nan ???????????
What is wrong or how to make these data usable?
Thanks in advance!
regards
Zbigniew
dr Zbigniew Perski
Geological Visualization Laboratory
Department of Fundamental Geology
Faculty of Earth Sciences at UNIVERSITY OF SILESIA
Bedzinska 60, 41-200 Sosnowiec
POLAND
fax: +48 32 2915865
phone: +48322918381 e.420
http://kgp.wnoz.us.edu.pl/insar
