[GRASSLIST:1701] v.proj bug?
    David Orme
    d.orme at imperial.ac.uk
    Thu Nov  6 10:57:24 EST 2003
I e-mailed a while back about a problem with s.proj - I've encountered
something similar in v.proj.
I have a raster dataset in the old New Zealand South Island grid
(Transverse Mercator: central meridian 171.5E, latitude of origin 44S,
scale 1, false easting 500000, false northing 500000, units yards,
ellipse international). This projection is included in ArcMAP and when
I compare a graticuled map in ArcMAP to (coarse scaled) printed grid of
the raster  for the dataset, there is a very close match.
I've tried to set up a GRASS location to match this (I've appended the
PROJ_INFO) and downloaded the DCW vector coastline to use as a base
map. I imported this into a latlong location and v.proj'd it across and
found that the coordinates did not match ArcMAP. I've picked two South
Island locations as test sets  - Cape Providence (bottom left) and the
tip of Farewell Spit (top right). These have the following lat longs
(in s.in.ascii format and cs2cs):
166:27:28.0E 46:00:55.0S Cape_Providence
173:01:05.1E 40:33:28.8S Farewell_Spit
166d27'28.0E 46d00'55.0S
173d01'05.1E 40d33'28.8S
In ArcMAP (and through a separate NZ grid application for Classic Mac
and approximately from my printed grid) these have the NZ SI
coordinates:
72976E 241337N Cape_Providence
640603E 916716N Farewell_Spit
I've run the vector file and these two coordinates through cs2cs: the
vector file imported through cs2cs and the e00 imported through v.proj
overlie exactly and the coordinates of the points out of cs2cs are:
119772.29E 288333.97N Cape_Providence
687425.44E 963732.29N Farewell_Spit
The cs2cs arguments used were:
cs2cs +proj=latlong +ellps=clrk66 +to +proj=tmerc +lat_0=44S
+lon_0=171.5E +x_0=500000 +y_0=500000 +ellps=intl +units=yd
I have also tried moving the units argument to earlier in the argument
list:
cs2cs +proj=latlong +ellps=clrk66 +to +proj=tmerc  +units=yd +lat_0=44S
This _does_ change the coordinates, but unfortunately not to match
ArcMAP:
109519.78E 263652.58N Cape_Providence
628581.82E 881236.81N Farewell_Spit
Any suggestions?
Thanks,
David Orme
New Zealand South Island Location PROJ_INFO:
proj: tmerc
ellps: international
a: 6378388.0000000000
es: 0.0067226700
f: 297.0000000000
lat_0: -44.0000000000
lon_0: 171.5000000000
k_0: 1.0000000000
x_0: 500000.0000000000
y_0: 500000.0000000000
