[GRASSLIST:1752] Re: Re: Newbie - error: d.dmrc doesn't exists
Roger Bivand Roger.Bivand at nhh.no
Thu Nov 13 07:37:17 EST 2003
On Thu, 13 Nov 2003, Jakob Lanstorp wrote:
> > I believe this means that you are using PERMANENT as your working mapset.
> >Have you tried starting GRASS in a different mapset in
> > the location?
> The sample data spearfish and the global dataset only seems to have one mapset
> present, i.e. the PERMANENT one ?
Depending on whether you start GRASS in graphical or text mode, the way
you create a new mapset differs; in text you enter the new mapset name,
and confirm that you want to create a new mapset. If your file system
permissions will not let you, create the mapset directory as root user,
and chown it to your login.
> Or do I have mistaken some think.
> Thanx,
> Jakob
> > > When running the Display Manager, I get the error:
> > > File /home/Grass/Globaldata/global/PERMANENT/ .d.dmrc doesn't exists.
> > > I have tried the spearfish and the global dataset from
> > > http://grass.itc.it/data.html
> > > How can I handle that error and get to view the map.
> > > Been looking at: http://grass.itc.it/gdp/grass5tutor/HTML_en/c407.html
> > > Thanx,
> > > Jakob
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
