[GRASSLIST:1762] Re: m.proj2, Wingrass Generic, Cygwin, Windows XP
Hamish
hamish_nospam at yahoo.com
Thu Nov 13 20:01:41 EST 2003
> I have problems with the m.proj2 module. In conversions from ll to
> laea with the international ellipsoid, a shift occur so the module
> does not work. I miss the m.proj module in grass 5.0.2. Does anybody
> know where I can get the m.proj module for 5.0.2. Thanks a lot, Jan
Does the version in 5.3-cvs work? You should use 5.3 if you want support
for datum transforms.
Is that from ll-wgs84 or ll-intl (ie datum transform)?
Hamish
